David Mac
Hi all, frequent reader, first-time poster. Just bought a home with the intent of finishing out a walkout basement. Relevant info: I'm in GA, which has adopted IPC 2012.
Put together my plans for installing a WC, two lavs, and a shower; all the stubs had been put in place already by the original builder. Then I discovered a 3" drain stack that ran the whole length of the house instead of straight down into the waste stack for the basement fixtures. Why, I asked myself.
Got in touch with the original owner/builder - he said what the county told him the sewer depth was, and what it actually turned out to be was off by 3', which meant he had to re-route the 1st floor and above to a different drainage system and couldn't use what he'd buried under the foundation. Bummer.
But the pipes are still there, and they feed outside the house (all the way at the other end of the slab from the stubs) and are ready to be connected to... something.
A couple of options I have, then - and would like to hear opinions/others before I hire it out to a master plumber.
(a) Install a macerating toilet, upflush into the rerouted stack, and use gray water undersoil irrigation from the lavs and shower. (I don't think I'll choose this, as it probably requires too much additional concerns from the gray water system.)
(b) Install an ejector pump
(b1) Break foundation and install it inside the basement - discharge into existing line (and vent - can I combine with another dry vent system, or do I need dedicated? Are most ejector pumps considered "pneumatic" per IPC 2012 906.5.2?)
(b2) Install it in the pipes that feed outside the house and inject it back into the house (how to protect against freezing? Jan avg. low is 29F), venting at ground-level (will it stink up the neighborhood?)
I'm expecting these to all be low-use fixtures, only in use when the MIL is visiting.
Thanks all for your help!
