DW85745
I've isolated the Leak to the Down Stream side after the Hot Water Tank.
The Connections from the Hot Water Tank to the Wall are OK.
Anyone have any ideas for:
1) How I isolate the lines from inside the wall to each hot water faucet for leak testing, and
2) Once the problem line is identified, find the approximate location of the leak?
This house is on pier and beam s0 I can check a small portion of some of the lines under the house for any visible evidence of water -- work in progress.
However most of the lines are hidden and buried below grade, with about
a two foot thick concrete floor on top (think of a basement floor with just a 19 inch crawl space between the top of the basement floor and the bottom of the floor beams (joists)).
There does appear to be some sort of manifold assembly for pipe routing (no valves) in the crawl space area below where approximately the hot water tank is located above in the living space.
Any other approaches (including a workaround) appreciated.
