Hi,
I'm required to pass final plumbing air tightness test... or bowl test. i.e cap the roof vents, cap the main clean out. fill a traps with water... let the toilet bowl fill up slowly... in a air tight system it should hold water... i.e One inch of water column. Alternative be the manometer test in north central area. i.e U shaped tube pushed through the toilet and should rise up to 1" after air or water is run.
In my case it will only hold at 1/2 inch of water column any thing more the traps are blowing. I.e blub in the toilet that lets the air out.
We have tested the whole line by pumping with smoke (supperior smoke candle 3minute), tested further using peppermint test... (2oz perpmint pourd down roof vent, followed by hot water) could not smell any thing in the house. Confirmed it went through out the system... as once the main clean out was released could smell it.
So question is why do my traps blow before 1" inch of water column pressure is reached.
