Filter configuration help
So the carbon tank that i have looking at says it catches sediment too. I know this isn't the primary job of the carbon filter but would i be able to use it to catch sediment or should i still have a dedicated sediment filter prior to water entering the tank and would the contact tank work as a sediment catcher?
well > sediment filter> injection> contact tank ( if needed) > carbon > home
well > injection > contact tank (if needed) > carbon > home
After speaking with an electrician seems like the better idea would bit the bullet and add an insulated wellhouse and place all the equipment in it. I can run electrical easier and maintenance will be a lot easier plus i can add drainage for a backwashing filter.
You will need some type of particulate filtration between the retention tank and the carbon tank. Bannerman is leading you in the correct direction with backwashing Katalox, etc. If 7 GPM is the pumping rate from your well you will need to be cognizant of that, and will be limited to a 10" diam. tank if using Katalox.
A carbon tank or Katalox Light tank can do filtering too, as long as the sediment from the contact tank is fine enough, and I expect it is. The fine sediment gets backwashed out. Watchwater points out that a KL stage will filter down to 3 microns. https://watchwater.com/katalyst-light-iron-manganese-and-hydrogen-sulfide-removal/
I expect carbon to act similarly. I use my Centaur Carbon tank as my front end, and that includes a bit of sand/pebble filtering. I maybe should have added a course filter before that, but I think most sediment from my well will be small enough to backwash out, and the rare pebble would act as a bit more gravel. The volume of course sand or pebbles would be very small in my case.
Thank you guys for all the help. I have some sediment but it is very fine almost like silt and accumulates at the bottom of my big blue filter and there is not a lot of it but its there.
so if that is the case could i just remove the sediment filter since its a point of resistance and just treat the water then contact tank then carbon tank and it will all get backwashed out? I would think if it is very fine and the contact tank will let sediment settle to the bottom and any that gets pushed through will get trapped by the carbon. This would make me have to drain the contact tank every so often but the one I'm looking at has a bottom drain.
One of my main worries is adding to many tanks and media will lower my water pressure too much. im hoping the bigger tanks will allow for more water flow and less clogging.
IMO, you normally do not want a cartridge filter before a backwashing filter due to the pressure/flow drop. You want that backwashing filter to see at least 30 PSI I think. A 7 GPM filter can usually deliver 8 or 9 GPM at 30 PSI. But a cartridge filter would likely reduce the flow. A course wye filter could take out course stuff without as much pressure drop.
Removing would probably help with my not wanting to lower my water pressure. with very fine sediment and not a lot coming through the contact tank and carbon tank might be able to backwash it out and not need the sediment filter.
I've read a couple different things but would the katalox light help with iron bacteria? it seems generally iron filter will foul with iron bacteria but after watching and reading some stuff from Mid Atlantic Water he say that KL can deal with iron bacteria too.
We are not talking about filtering out just sand or pebbles. The OP will utilize a chemical feed to oxidize 0.5 ppm iron and disinfection for IRB. It is not a good idea to rely on the carbon tank to filter these oxidized materials. Use Katalox, Greensand, Nextsand, something in between for filtration. Bannerman laid it all out in a previous post so no need for me to retype it all.
Any type of media, including water softener resin, will provide some amount of sediment filtration, but sediment filtration is not typically the intended purpose for most.
Carbon is not considered to be an effective physical sediment filter as the filtration range for granular carbon is about 20-25 microns or even larger, thereby making it poorly suited for trapping suspended solids like dirt, rust, silt, or sand. Because carbon primarly works by adsorbtion, it is best utilized for removal of organic chemicals and odors, and for improving taste and color.
When iron, manganese and H2S is in a Ferrous state which is the most common state in water exiting from a deep well, those elements will be fully dissolved in the water, so they can't be simply removed by sediment filtration. Once oxidized, those elements become converted to a Ferric state, which will no longer allow them to remain dissolved in the water. The resulting undissolved solid particles (ie: ferric iron = rust particles), will then begin to precipitate out from the water while the water flow rate is low (ie: within a large diameter contact tank) or in pipes whenever the water is not moving. The most effective and complete removal method will be by passing the water through appropriate sediment filtration media.
Katalox Light was specifically recommended. Not only will KL provide oxidizdation and catalyzation of Ferrous Iron, Manganese and H2S, but is also a highly effective sediment filtration media, capturing particles down to as small as 3 microns. Routine backwashing of the KL media will then lift and circulate the media, thereby forcing captured solid particles to be released and flushed to drain, while also reducing the potential for channelling to ocur through the media.
When there is any type of persistant bacteria present directly from a well, chlorine is often recommended for injection directly prior to a KL media filter. Chlorine will not only neutralize bacteria, but will also enhance and initialize oxidation prior to the water coming into contact with the KL media. The upper level of KL media can then continue to finalize oxidation of any remaining ferrous elements, allowing the remaining KL media below to filter out and capture the resulting ferric solids.
Although you may be currently observing only a small amount of physical sediment/debris in the water directly from your well, once the ferrous iron, manganese or H2S become converted to a ferric state, depending on the quantity of each, there is likely to be a significantly larger quantity of physical debris to be removed. Removal of the sticky ferric solids prior to the carbon system, will then allow an appropriately configired carbon system to better fullfill the task it is intended to perform, that is, enhancing the quality of your water by removal of any remaining chlorine and other chemical contaminants, along with improving the taste and color prior to supply to your home's fixtures.
As previously stated, you will require a comprehensive lab test to determine which elements and the quantity of each in your raw well water. As iron, manganese and H2S removal will be most effective when water pH is neutral or somewhat alkaline (7.0 pH = neutral, 7.5 - 8.0 optimal), your lab test should also indicate the pH level.
Carbon is not considered to be an effective physical sediment filter as the filtration range is about 20-25 microns or even larger, thereby making it poorly suited for trapping suspended solids like dirt, rust, silt, or sand. Because carbon primarly works by adsorbtion, it is best utilized for removal of organic chemicals as well as removal of odor, taste and for color improvement.
Are you thinking that if Quadzilla32 does H2O2 injection followed by a contact/retention tank, there should be some added filtering done before the GAC? I would put a cartridge downstream, but not upstream of the GAC. I am not saying that my opinion the right way, but it seems worthwhile for discussion.
In an H2O2 system, I think the GAC is primarily there to remove the residual H2O2.
While H2O2 (hydrogen peroxide) is a highly effective oxidant, beneficial for oxidation of ferric iron, manganese and H2S, it is not stable and therefore not usually recommended when there is any type of bacteria present, unless injected at a much higher rate or given much longer contact time compared to that needed for chlorine alone. This is due to H2O2 decomposing back to its native H2O and O2 state, with the speed of decomposition increased when exposed to certain metals which maybe present in the water or filtration system. Unless 100% of the bacteria has been neutralized, a rapid H2O2 decomposition will often worsen a bacteria problem. Iron reducing or sulfer reducing bacteria are somewhat stubborn, often requiring longer contact time compared to many other types of bacteria.
Although effective for removing residual H2O2, either a GAC or Cataylitic Carbon system will rapidly remove residual chlorine, much faster than many other chemical contaminants. Measuring chlorine leakage to assess when to replace carbon media is not a effective method since carbon will continue removing chlorine, long after its capacity for removing many other contaminants has been depleted.
With regard to a sediment filter placed after a contact tank but before a backwashing carbon system, at this point, we really don't know the water conditions, the amount of oxidant of any type that will be needed, the amount of debris likely to accumulate, or the size of contact tank planned.
If the flow rate to the home's fixtures is usually 3 gpm, then a 120-gallon contact tank should provide about 40-minutes contact time, whereas if the flow rate is 6 gpm, then the contact time will be reduced to ~ 20 minutes. In either case, we don't know how rapidly oxidation will occur to allow sufficient time for solids to settle to the bottom of the contact tank so as to not to exit the top outlet and flow into the carbon system.
