Filter configuration help
Quadzilla32
Colorado
Hello,
Backstory:
I just moved into a new place that's on a new well and going through some growing pains. Water was tested only for harmful bacteria prior to moving in. We had culligen just do a simple water test and was told only thing out of normal range was iron which was at .5 ppm (ferrous), so barely out of the "normal" range. Currently have a tap score water test on order just waiting for it to arrive.
We started to see some light iron staining and sediment so added a spring well 3 phase filter (sediment, iron, carbon). This is where the issue started is that my filters were started to get clogged VERY quickly. I had to change them out after a week or two or else my water pressure would get worse and worse until it would eventually trickle out. These filters are supposed to last 6/12 months so something is clogging them prematurely.
From research it appears that it might be iron bacteria that is causing the filters fouling so early. I had some red/brown sludge forming in my toilet tanks. Also, when i changed out my filters there would be some red staining on the outside along with some musty smell. I am also getting some sulfur smell which i believe is hydrogen sulfide coming through my cold tap. I did recently also change out my anode rod in my HWH and shocked my well but it didn't help for very long.
Filter Idea configuration:
It appears that I need to add some chemical injection to help knock down the bacteria and this is where i start having questions. Currently my set up is in a concrete well pit that is roughly 8/10 ft down. inside that i have my well switch and pressure tank along with my filters. if i was to add an injection kit it appears peroxide would do the trick and be better/safer for iron bacteria and any hydrogen sulfide.
I have seen contradicting statements that i would not need a contact tank and others saying yes i would. This also brings up where I inject the peroxide, if i inject it before the pressure tank would it turn the pressure tank into a semi contact tank? I know this is not the purpose or ideal for the tank since the oxidized minerals would settle in the tank and the peroxide itself can harm the bladder. If i was to inject it after the pressure tank would there be enough time? My concern is this the pit not being very big it might take some Tetris to get everything in there. Currently there is outlet for 120V but I'm trying to get one in but if i cant wiring it prior the the pressure tank an tapping off of the pressure switch might be the only option so it would go before the pressure tank.
After the injection would i still need the iron/ carbon filter and if i kept just the carbon filter would it be ok handling the oxidized iron, etc..? Would I also need to put the sediment filter right after the injection either between the injection and retention tank if i add one or keep the injection then pipe it to the three phase filters. Would the retention tank filter out some sediment?
This also brings up another issue that i currently do not have an outlet or drain in the pit so an auto backwashing carbon filter is currently not an option. I am trying to remedy that by adding some power and possibly a drain. I see there are manual backwashing carbon filters so that might be an option. While not ideal it would give me a larger carbon filter option.
options 1: injection either before or after pressure tank and possible retention tank if needed > keep 3 phase filter set up > Home.
Option 2: > remove three phase filter and just add one large catalytic carbon filter either manual/ automatic backwashing (I'm not sure if the single filter will be enough to remove everything) > Home.
I just want my filters to last longer than a couple weeks, its getting tiring and expensive to have to swap them out so much.
Well is 709ft deep pump sits at roughly 500ft and static water is 320ft. pumping 7 GPM
Thank you!
-Mike
You seem impatient.
1. I don't know about your "3 phase filter", but I expect those are 3 small cartridge filters. If they told you they were going to last 6 months for you, they were wrong.
2. H2O2 injection can oxidize iron so that it can be filtered out. It can also deal with H2S. Your comments about injecting before the pressure tank and using the pressure tank as your contact+setting tank sounds right. Better is to inject with proportional injection after the pressure tank, and then have a contact tank following that would be better. A blow-off valve to blow out sediment from that contact+setting tank would be good.
Proportional injection takes more expensive hardware.
A coconut GAC filter can do some mechanical filtering and remove residual H2S. That is what you would probably use. Figure to swap carbon maybe every 5 to 7 years.
3. Pouring bleach helped the H2S for a while. A more effective sanitizing would probably last longer. https://terrylove.com/forums/index....izing-extra-attention-to-4-inch-casing.65845/ is my write-up for more effective sanitizing.
4. Backwashing iron filters can take a lot of GPM. 5 GPM can backwash a 10 inch GAC tank, but you need more for Katalox Light -- about 8 GPM for a 10 inch tank.
5. You mention a WH anode. Magnesium anodes, and to a lesser extent even aluminum+zinc anodes can contribute to SRB producing H2S in the WH. A powered anode can protect the WH without helping SRB grow. I would go with the AO Smith powered anode rather than the stubby one.
You seem impatient.
I know it water quality dependent but saying it will last X amount of months/ gallons i would expect it to last longer than 2-4 weeks. they are 4.5 x 20 cartridges in big blue housing.
Ya i was looking at a 30 gallon contact tank with bottom drain valve. its just space is at a premium right now so if i didn't have to use one then i could save some space. Another deciding factor is trying to kill iron bacteria ive read you need a contact tank to kill it off and then some say you don't need a contact tank. Another issue is that right now the only way to get power to the injection kit is wiring it to the pressure switch BEFORE the pressure tank. I would rather do it after to not fill the pressure tank with crap. Again, trying to get some 120 ran to the well pit.
I'm still looking at what carbon to use seems like catalytic carbon does the best. im sitting right at 6/7 GPM
Thank you ill take a look
Would i still need an iron filter if I oxidized everything or would the carbon catch everything? If i can get rid of the 3 phase and just use the peroxide > sediment > Carbon > home, would i need the sediment or would the carbon tank kind of do it all? Taking out some equipment would free up space and give me a little better water pressure hopefully.
the aluminum seems to be helping the smell seems to be more predominant in the cold tap leading to believe its coming from the well, but might take a look at a powered anode. It also seems to only be an issue if the water sits for a while, iff the water is continuously used the smell isn't there just when its been sitting for hours.
I am not a pro. If you oxidized everything, I think you don't need a separate iron filter. I would have a cartridge filter after the carbon, and maybe after the softener.
I use Centaur carbon as an H2S+iron filter. It gets backwashed at 5GPM and then dosed with a chlorine bleach solution.
A softener removes any residual iron, but it would need some extra attention if removing much iron.
If you are going to keep a pit, a sump pump would also be worth considering in there. Well seals don't seal. I used to have a pit, but I got that demolished and a pitless installed. I got motivated by washing my pit floor with a lot of laundry detergent, and then later seeing suds in my drinking water.
It sounds as if you want to put your treatment stuff into the pit. That sounds hard.
I have tossed around the idea of moving everything out of the pit. This would be the more expensive option since i would need to build an outside well house and then run electrical to it and insulate it from freezing during the winter. trust me i have thought of this and making everything a lot easier i would just be worried about keeping it heated during the winter and not running up my electric bill. Its not that I want to keep the pit it just seems the easiest and cheapest way to do it if i can in my current set up.
my water is actually soft so the water softener wouldn't necessarily be needed. when you say cartridge after the carbon you mean after the carbon tank just have an iron filter if anything gets by? I'm still waiting for my well test kit to come in but was told that my iron level is .5ppm
Current set is is similar to this with the exception of it being thick cement and 10 ft down with only the pressure tank. The well head is above ground. the cement casing is roughly 6 feet wide and slopes up to a little opening that is covered by a cement top, kind of like a cement manhole.
Using cartridge filters on a point-of-entry application, maybe adequate as a supplimental measure for when there are minimal or no known water issues, but when there are identified problems, a proper treatment plan is required.
Before treatment descision can be made, you will need a comprehensive lab test performed. I'm not familiar with 'tap score' as the most common testing lab recommendation on this forum has been National Labs. Their Well Check STANDARD linked HERE is the usual recommendation. Perhaps, hopefully, the 'tap score' test will be comparable??
When you obtain your water from your own well, you are the water supplier so you are responsible for not only water delivery, safety and also water quality. Without a comprehensive lab report, you don't fully know which conditions exist so you really don't know which treatment methods will be needed, benefitial or most effective. While free tests offered by various equipment dealers maybe tempting, keep in-mind, suppliers benefit from selling water treatment equipment. Obtaining your own independant lab test, places you in the best position as you can then more easily compare similar treatment methods from multiple suppliers based on equal (and highly accurate) water specifications, with less pressure to force purchase based on equipment that dealer has available instead of what is actually needed or will be most effective for your specific conditions. Once effective treatment method(s) are in-place, always advisable to have your raw well water re-tested every few years since water conditions can change over time.
Regardless of construction material, well pits have been outlawed in much of the US due to the high potential of ground water contamination into the well since the top of the well (and pressure tank/switch) is located below the surface level. It's too common for a pit to fill with water.
If your home is equipped with a basement, crawl space or even 'warmish' garage, you could relocate the pressure tank and switch as well as any treatment equipment inside, thereby eliminating any requirement for an additional heated well house. Once the pressure tank and switch is relocated, prior to backfilling the exisiting pit, your well casing can be extended to ~2' above surface level, while permitting a pitless adaptor to be installed through the casing below the frost line, to supply water to the house.
Using cartridge filters on a point-of-entry application, maybe adequate as a supplimental measure for when there are no known water issues, but when there are identified problems, a proper water treatment plan is required.
Before water treatment descision can be made, you will need a comprehensive lab test performed. I'm not familiar with 'tap score' as the most common testing lab recommendation on this forum has been National Labs. Their Well Check STANDARD linked HERE is the usual recommendation. Perhaps, hopefully, the 'tap score' test will be comparable??
When you obtain your water from your own well, you are the water supplier so you are responsible for not only water delivery, safety and also water quality. Without a comprehensive lab report, you don't fully know which conditions exist so you really don't know which treatment methods will be needed, benefitial or most effective. While free tests offered by various equipment dealers maybe tempting, keep in-mind, suppliers benefit from selling water treatment equipment. Obtaining your own independant lab test, places you in better control as you can then more easily compare similar treatment methods from multiple suppliers based on equal (and highly accurate) water specifications, with less pressure to force purchase based on equipment that dealer has available instead of what is actually needed or will be most effective for your specific conditions. Once effective treatment method(s) are in-place, always advisable to have your raw well water re-tested every few years since water conditions can change over time.
Regardless of the construction material, well pits have been outlawed in much of the US due to the high potential of ground water contamination into the well since the top of the well is located below the surface level since it's too common for a pit to fill with water.
If your home is equipped with a basement, crawl space or even 'warmish' garage, you will likely be able to relocate the pressure tank and treatment equipment inside, thereby eliminating any requirement for an additional heated well house. Once the pressure tank is relocated, your well casing can then be extended to ~2' above surface level, thereby permitting a pitless adaptor to be installed through the casing below the frost line, to supply water to the house, prior to backfilling the exisiting pit.
the well head is above ground and the pressure tank/ switch are in the pit. I do not have a garage and no basement or space in my house to put equipment so either i putt he stuff in the pit or i build a well house and put all the equipment in that.
Think the term well pit means different things, the head is not below ground.
The photo you posted, although showing the top of the casing extended about 12" above the pit bottom, clearly shows the top of the well casing located below the ground surface surrounding the pit.
As stated, pits will commonly fill with water, sometimes up to the surrounding ground surface level. Even if filled to a lower level (ie: 13"), not only would contaminated ground water enter your well, but your pressure switch will be submerged, likely causing your pump's electrical service to become shorted to ground.
correct the well cap and there is about a foot of casing sticking out.
I would call ground level the ground surface outside of the round corrugated steel, rather than the dirt floor within the circle. You too?
sorry for the confusion the picture i posted was only to give an idea of the concrete pit with a cover and inside there is the pressure tank.
inside my pit there is only a breaker for the switch and the pressure tank. the cap is about a foot away with a foot of casing sticking out.
This closer resembles mine with teh exception that all the wiring/ pex is running under the cement. add a breaker and the phase filter on the wall and that is what mine looks like with the casing sticking out above ground.
You have still not clarified what you mean by 'above ground'.
This latest photo, which it seems is not your actual pit, continues to show the top of the well casing extended only about 12-18" above the bottom of the pit, which still remains below the actual ground surface.
When we state 'ground surface', we are not meaning the dirt at the bottom of the pit, but we are referring to the ground surface surrounding the pit. Your original photo shows the pit's surrounding ground surface covered by gravel.
As per a G search:
If a property features a well pit, it is typically grandfathered in under older regulations, meaning it is not immediately illegal to own, provided it remains clean, dry, and safe. [1]
However, strict legal triggers apply if the system needs modifications:
    • The Replacement Rule: If the well pump requires major servicing, or if the well needs to be altered, most state codes mandate that the pit must be legally terminated. [1]
    • Decommissioning: A licensed well driller must extend the well casing to at least 12 inches above the ground level, install a modern pitless adapter below the frost line, and structurally fill in the old pit with soil or concrete. [1, 2]
Why Well Pits Were Outlawed
Well Pits—underground concrete or block rooms dug below the frost line to keep well equipment from freezing—were banned due to severe public health and safety risks: [1, 2]
    • Water Contamination: Pits are highly prone to flooding. When surface runoff, melted snow, or rainwater fills the pit, contaminated water can leak directly down the well casing and pollute the local drinking water aquifer. [1, 2]
    • Asphyxiation Hazards: Well pits are classified as dangerous "confined spaces". Decaying organic matter or localized gas buildup can displace oxygen, creating a fatal environment for homeowners or contractors who climb inside. [1, 2]
    • Safety and Wildlife: Old pit covers can deteriorate, creating a fall hazard for people and livestock. Additionally, they frequently become breeding grounds for insects, rodents, and snakes. [1]
As per a G search:
Looks like this next to the well pit. so im guessing there is a pitless adapter on the casing since its only electrical coming into the well cap. This is a brand new well/ build so everything passed code and inspection.
That clarifies it, if that is a photo of your casing.
No but pretty much what is looks like casing coming out, a well cap, then conduit running the wiring from the pump inside the casing to the breaker box in the pit which is 2 feet away and buried.
We only know what you describe or show us in photos.
Your original photo, shows the pressure tank/switch being fed from the well casing within the pit. Is that photo not up-to-date?
For the reasons specified above, the existing pit should rightly be eliminated and filled in.
I expect with them being so close, your new well is likely obtaining water from the same aquifer as the old well within the pit. Any leakage into the old well casing, then has the potential to contaminate your new water supply, and possibly other wells within the area.
The usual benefit for carbon filtration, it to reduce/eliminate chemical contaminants, reduce odor and improve the water color. Catalytic Carbon is also more effective at removing H2S compared to standard GAC (granular activated carbon). Because either type of carbon requires sufficient contact time to work most effectively, the recommended flow rate is between 1-3 gpm per CUBIC FOOT (ft3) of carbon media since various contaminants require longer contact time for removal to occur. A 4.5 X 20 cartridge contains only ~ 0.11 ft3 of carbon media, so with so little media, the effective flow rate will be minimal, typically sufficient for point-of-use applications, not point-of-entry.
For iron and/or H2S issues, the usual recommendation will to utilize a separate 1.5 ft3 (or larger) tank of Katalox Light media, which is equipped with a control head to permit the media to be backwashed on a regular and frequent basis. In addition to being a very effective sediment filtration media (<3 microns), KL does provide oxidation action to convert ferrous iron, manganese and H2S, each to a ferric state which is then removed by the remaining filtration media. Depending on water conditions, the oxidation capability will often be enhanced using air (not recommended when there is any type of bacteria present), hydrogen peroxide (also not recommended for bacteria), ozone or chlorine (both effective when there is bacteria present). Not only does backwashing flush away solid debris resulting from oxidation of ferrous iron/manganese/H2S into a ferric state, but also loosens, lifts and circulates the media within the tank, which enhances the media by eliminating the potential for channelling.
A backwashing (minimum 1.5 ft3 or larger) carbon system will then be typically utilized to remove any remaining chlorine, peroxide or ozone, and will also polish the water, thereby reducing any remaining odor and chemical contaminants, improving the water color and quality directly before being supplied to fixtures.
So the carbon tank that i have looking at says it catches sediment too. I know this isn't the primary job of the carbon filter but would i be able to use it to catch sediment or should i still have a dedicated sediment filter prior to water entering the tank and would the contact tank work as a sediment catcher?
well > sediment filter> injection> contact tank ( if needed) > carbon > home
well > injection > contact tank (if needed) > carbon > home
After speaking with an electrician seems like the better idea would bit the bullet and add an insulated wellhouse and place all the equipment in it. I can run electrical easier and maintenance will be a lot easier plus i can add drainage for a backwashing filter.
Subpanel in insulated wellhouse, near but not over the well, makes sense. That way you can can get the well serviced without having to disassemble the wellhouse.
Add an outlet for yard stuff, charging future robot mower, and whatnot.
ya i would leave the cap and casing exposed and just put the injection kit and filter components in the new house. Im still kicking around the idea whether or not to pull the pressure tank out too or leaving it in the pit. The pit is sealed and covered and has the electrical already in place so it would only be routing the water line to the well house then back to the main line. Which in theory should be fairly simple since i can maneuver the well house so i would just need to dig up the line route it to the well house about 2 feet away then tie back into the already existing line to the house.
