Filter backwash to floor drain
Powerless
Ontario, Canada
Hello,
Is it up 2 code to drain filter to floor drain.
I believe that drain is connected to sanitary system not to storm water or sump.
( I will get plumber to snake it )
I do have access to main stuck but no vent and I don’t want to use those little no vent things.
Thank you
You can, but you should elevate the output above the grate, commonly illustrated by tying the line to a brick.
The flow can be high on a backwashing filter... 5 or 10 gpm is not uncommon, and it can be higher. You would usually put an elbow in the end to direct the flow to the grate. Expect splashing.
