krich
Hello, I am new on this forum and could use some diy advise on a plumbing project. I have taken out a tub and am building a tiled shower and conc sand bed floor. I need to connect from a 1-1/2" tub drain to a 2" pvc shower drain. This is in manhatten and the existing tub drain is a metal tubing into a cast trap and horizontal run into an abs main. I had advise to use a fernco coupler on the metal vertical tubing. This would be easiest but is it reliable? Would the other option be to cut the cast trap out and somehow attach a pvc (trap) onto the cast horizontal pipe? See pics, you cant see the trap directly under the water line. Thanks
