purduephotog
Forgive the title, for I hath been fighting a wet wall, a screaming 2 year old, an incompetent previous owner's repair, and a FLIR camera that wouldn't load. (Actual question below in bold)
That said- I awoke to the sound of a 2 year old chanting "What's That" over and over, which turned out to be rain leaking in the windows. Unfortunately, it wasn't raining and the wife was showering. Undaunted, I pulled out the trusty FLIR and saw (1225). A big fat hot spot next to an otherwise unassuming wall.
Not knowing the damage or how long/far (I have thus assumed it was a leaking gasket around the drain), I opened the wall to dry it. I discovered not one, but TWO non-shielded Fernco gaskets. It was as if the individual previously just decided to cut out huge chunks of pipe and put them back with the easiest thing at hand.
This also appears to be my sewer stack, so I'm REALLY not looking forward to opening this. The shower drain pops through a convoluted 180 straight into the stack, and the fiberglass floor pan does NOT appear to have any support up and around the hole they cut (Because, why not? everything else in this place is wrong).
I know the right thing to do. Really. Take out the fernco, buy a 3" saver bit, drill out the old PVC pipe, attach new. Properly support. Rip out the shower, correctly support the bottom pan, put in new shower (while fixing toilet and updating decor). So I'm not looking for 'illegal' shortcuts here.
What I am looking for is suggestions as to how to defer the repairs until I can not be on the road for a week OR figure out how to fix both bathrooms (Very tiny and awkward). Thus... since I now have access (limited) to the bottom of the shower fiberglass pan, should I go for the gasket and offset drain (Assuming I can find)? Is it possible to support or provide expansion foam into the bottom of the fiberglass area to carry some of the load as well? (Heck, it can LIFT concrete, is water proof, and sticks to everything)?
I'm just flabbergasted at all the shortcut this guy took. I want to fix it right, however gotta earn that money first. (Yes I find it ironic I am using a high res FLIR camera to locate leaks)
More photos when I can get them off the phone.
