James23912
Kind of confusing, but here goes. I have been living in a trailer for a few years and am now building a house in front of the thing, there is also a 24’ by 40’ garage/metal building, fully equipped. Power is underground and the meter and 200 amp breaker are located on a post near the garage, with two sets of wires coming from the meter box, trailer and house about 75, away, so I am wondering if this means they are piggy backed, meter and panel are sealed so I can’t look. Garage has a 70 amp breaker, trailer is 100 and house is 200, meter panel is 200.
what I am thinking is, if two things can be fed from one box, then could I undo the garage wires and connect the new house wires, not using them until I move and then shutting off power in the trailer. I had been planning on switching the power over when I do finally move but work is slow and probably won’t move til early winter, so if I could connect now it would be much easier. I would have to have the,power co come back at some point to disconnect the trailer wires and hook the garage back up. The house panel would be done before doing anything.
I will be having a licensed guy do the connecting but he gives me the run around when I ask him stuff so I figure I will ask here first
so basically the question is just about attaching two sets of wires to the meter box, I assume what I already have is legal, it was done around 1992, I believe.
I should add that there is a disconnect switch at the meter box
