Rreeuuvveenn
Hi experienced team,
we have a 310 feet well, around 1500 gallons a day, in California,
1 HP grundfos pump, since 2008, 1.25 inch pipe,
static level tube does hold air pressure,
did put a clamp on ampmeter, 8.7 amps, after few minutes starts flickering, one amp up and down
from FE pumptec manuel:
"Yellow Load Indicator Light"
The yellow load light indicates one of three conditions:
- A solid yellow light with no flicker indicates a dry well (underload). This is caused by the load of the motor going below the underload adjustment knob. (If you have a Pumptec remote control, this will be indicated by underload in the Pumptec Fault History.)
- A solid yellow light with a slight flicker indicates an underload caused by a rapid decrease in load (approximately 25% over a twenty second period). (If you have a Pumptec remote control, this will be indicated by underload* in the Pumptec Fault History.)
any idea, should i be concern?
i can pressure and test the pipe,
and or disconnect a check valve at the well head,
thanks in advance
reuven
