J
Judy.M
Guest
Hello all,
Would you please share your opinion what solution would be the best for well water which has these parameters?
Fe 0.22 mg/l
Mn 0.374 mg/l
pH 7.11
KNK 4,5 2.35 mmol/l
CHSK Mn 0.05 mg/l
Total hardness 1.05 mmol/l
Dissolved solids (105 °C) 190 mg/l
Cl- 1.70 mg/l
PO4 3- 0.44 mg/l
NO3- < 1.00
NO2- 0.014 mg/l
NH4+ 0.01 mg/l
No issues with bacteria
The water looks completely clear after filling but after a few hours it changes slightly to yellow-grey color. There are yellow stains in sinks, shower corner and muddy deposits in pipes after 6 months of using it. It has no odour, only warm or hot water coming through boiler has egg odour. It tastes a bit metallic but it is drinkable of sorts.
I have decided to buy a filter which will help me to get rid of the iron and manganese but I do not know which would be the best and most effective from longer point of view. I want the backwash water to use for irrigation of lawns and hedge in the garden so it should not contain much of chlorine or salt, I guess.
First I liked oxidation with ozone but found out that there are nearly no products for use at home. Than I thought of H2O2 but it is not right for manganese. So it remains only oxidation with air, chlorine, permanganate or using of a softener with salt. I also do not know if a coated grains like Greensand would be sufficient or rather manganese dioxide should be used for such smaller amounts.
Thank you very much for your help,
Judy
Fe 0.22 mg/l
Mn 0.374 mg/l
pH 7.11
KNK 4,5 2.35 mmol/l
CHSK Mn 0.05 mg/l
Cl- 1.70 mg/l
PO4 3- 0.44 mg/l
NO3- < 1.00
NO2- 0.014 mg/l
NH4+ 0.01 mg/l
Judy
