I'm trying to stop a fairly slow drip through the spout of a compression bathtub faucet that has been in place since 1988. Replacing the flat washers worked for as much as six months in the past, but the seat surface has needed to be dressed periodically, and any more dressing will make it too short for the washer to reach adequately. I've already reached the point where I'm using beveled washers, but they're not lasting long, as the seats are wearing them away quickly. I don't want to try to replace the seats, because everything is this house is cheaply built, and I'm afraid something will break and require opening up the wall to replace the whole valve assembly.
The seats are a couple of inches long, and there used to be seat sleeves you could slip into place to provide a new mating surface, but I can't seem to find them anywhere. Do you know where they can still be found?
If I can't get seat sleeves, I was thinking of using a cone-shaped grinding stone to gently round off the inside edges of the seats, which are currently pretty sharp and cutting into the beveled washers. Is this a reasonable idea?
One other idea is to find longer bibb screws that would allow me to install two flat washers per stem to reach the shortened seats. The flat washers lasted longer than the beveled. I don't know whether the distances would work out. Might this work?
