Sonny123
Hi I'm trying to install this filter faucet and there seems to be a small leak between the filter and waterlines. The leak occurs from both from the intake line into the filter and water line from the filter into the faucet. The connection lines doesn't seem to be very tight and leaks if there's any slight bend in the waterline. The connection is just a simple push through connection (Tee connector?). See step 5d and 6 in the installation manual here.
My question is there some type of tape or sealant I can apply to make the connection water tight ? I really like the faucet even though I think they did not design this part of it very well. Thank you so much for you help !!
Sonny
Sonny
