Bob from accounting
Not sure what forum to post this in
I just installed a kitchen single hole faucet that has a handle which rotates back 45 degrees for hot and rotates 45 forward for cold. Straight up is in the middle of the two temps.
Our window trim sticks out to much behind the new faucet and the handle hits the trim and can not rotate fully back to the hot position.
So I need a faucet so when the handle is vertical, it is hot and when it is forward it is cold. The range it turns is something I am not sure how to determine in the description when searching.
How does one go about shopping for a faucet with this range in mind. Is there anything in the description I need to check.
Our current faucet does not go backwards as far and when I look at buying a new one, I am not sure how to determine the range of rotaion on the handle?
Let me know if you know how these are typically labeled or sold as, the verbiage or description I need to be tuned into?
I have attached a photo
Let me know if this makes sense.
I did remove the handle (via an alien screw) and rotate, offset the handle, but the cartridge does not rotate so the handle is vertical and fits, but the on off is then off axis is it is a funky on off, not in the direction of the lever, and is not a good solution. Also this is not about a stop limit for hot, but a physical range the handle moves.
