Faucet handle removal difficulty
acompanycog
Michigan
Hi All,
I installed a Speakman SB-2523 faucet two years ago, but the cold water handle has gotten hard to turn. I want to remove and loosen it. However, I can’t see how to take off the handle (the handles came assembled to the faucet body).
There is a small set screw on the base plate (not the handle itself), as shown in the picture to the right. However, when I took out the screw, it made no difference. I pulled straight up fairly hard, but I don’t want to break it.
It is only two years old so I doubt it is corroded or frozen with mineral buildup.
Any thoughts how I might do this?
unscrew the base and handle as a unit. the base will unscrew with the handle attached and rise off of the stem. the base is screwed on to this...(See red arrow)
