Extremely loud rattling sound during regeneration
mrt049
Sebastian, FL
This has happened with the past couple of regenerations but does not happen every time. My water softener regenerates every 3 nights at 3:00am. About 20 minutes before completion it sounds like a rattling/shaking sound and it wakes me up in a panic. I don't know if it's the pipes in the wall rattling or the actual softener but I have no clue what it could be. Do I need to have a professional come out and repair it or is this something that can be fixed pretty easily?
It doesn't sound like water hammer because it's not a tapping noise, it's a jarring sound like something being shaken up that lasts for about a second.
I used to have an old Autotrol that would howl loudly during the backwash, but that is the beginning of the cycle.
What is your softener, and how old is it?
mrt049
Sebastian, FL
I'm not 100% on the model because there are no markings on it at all. But this is my setup. The pressure tank is off to the left of this pic.
Interestingly, that softener controller appears to be an Autotrol Logix 740.
Looking around, I find people saying that a faulty air check valve can cause a noise problem well into the cycle. It may be that your air check valve is admitting a lot of air. When the next cycle stops, the big vibration/noise is generated.
In some Autotrol valves, the air check is part of the controller, but I don't see that in your photo. So yours is probably in your brine tank. You can replace the air check valve to see. Or get it replace by a professional.
https://www.softenerparts.com/kb_results.asp?ID=23
Incidentally, the Iron Boss iron+sulfur filter's tank needs repainting to protect it from UV, or get a tank cover for that. I also think that both controllers should have covers to protect them from UV, although I am not sure that the Iron Boss does not already have a UV resistant cover. A cover on each would not hurt.
ditttohead
Water systems designer, R&D
Ontario California
The rattle is from the Autotrol. A valve rebuild will usually fix this problem. This is a common problem with the flapper valve design of the Autotrol. The Flapper design is one of the simplest designs and very durable but when the valve tries to close sometimes they will rattle/vibrate violently. The materials have changed over the years to mitigate this but as you can tell, it still occurs.
If you detect air in your water after a softener regen, I would look to the air check. Otherwise, rebuild. Some people reverse the flappers in the Autotrol to get some more time on the old ones. But if you are getting in there, putting in new parts would be a better use of your time if your time is more limited.
ditttohead
Ontario California
Flipping the valves.., done that a few times. Never a good idea but... when you are an hour away and your out of rebuild kits... it works.
I would rebuild the valve and replace the aircheck. These parts are fairly inexpensive and will refresh your system to near new condition. The valve is very durable but those are considered wear items.
mrt049
Sebastian, FL
I'm not sure if this is something I can do myself as I have no experience with water softeners or rebuilding or anything like that. I'll probably have to call someone to do it.
