Extra POS heater to fill large bathtub?
Discussion in 'Shower & Bathtub Forum & Blog' started by Michele Boddy, Sep 24, 2020.
  1. Michele Boddy
    Michele Boddy New Member
    Sep 24, 2020
    California
    We are remodeling our master bath to include a 80 gal whirlpool tub (55g min/72gal max). We have a 100 gal gas water heater for the whole house in the garage. But the tank is on the other side of house from the tub. We already have a considerable wait for hot water in this bathroom. The tub comes with an in-line heater to keep the water recirculating through the jets warm. However, we were wondering if we should install an extra small water heater near the tub to ensure adequate ( capacity & temp) hot water? We would want electric since we have solar. We have space in an adjacent closet area and/or outside shed on that side of the house for a tank but maybe tankless would be better? Hoping someone can give advice/experience/ run numbers to see if the tub can be filled with enough hot water and fast enough so wont cool down to quick to have an enjoyable 30 min soak. Thanks ###Looking forward to my spa bathtub on the other side of the house from the water heater##
  2. breplum
    breplum Member
    Oct 2, 2004
    Plumbing and heating contractor
    San Francisco Bay Area
    Depending on so many different factors, there is no one right answer.
    PV electric would make it ideal to have a 100 gallon heat pump electric water heater. You should be able to get 70 gal. of hot water from the existing heater before it fades to warm.
    On the other hand, gas, while we are still using it, is fairly cheap (not green anymore) and a good condensing 97% efficient tankless water heater with a built in recirculating pump like Navien's NPE A series, and a new, insulated dedicated return hot water line from the far bathroom. You can even add a few push button user initiated pump switches if you want to get that upgrade on the Navien.
  4. WorthFlorida
    WorthFlorida The wife is still training me.
    Oct 28, 2009
    Retired
    Orlando, Florida
    The manufacturer has many point of use electric tankless heaters. Some are designed just for shower/tub use.
  5. jadnashua
    To get a useful temperature rise with an electric tankless requires a HUGE power input. Probably work fine for a shower, but not so much for filling a huge tub in a timely manner.
    80-gallons of water weighs about 665#. Say your water coming in is 50-degrees and you want the tub at 105 or so...that's a 55-degree rise times 665# = 36,575 BTU and your valve can flow 8g/min (say you are using a 3/4" valve to fill the tub faster than a 1/2" one). That's 1/6th of and hour, so since burners are rated at BTU/hr, multiply that 36575 * 6 = 219,450 BTU/hr. Now, you'll probably want the hot coming in a bit higher and mix some cold with it, but that's already more energy than a typical gas-fired tankless can provide, and if your wintertime cold water is colder than that, the energy needed just goes up proportionally. Where I live, my wintertime incoming water has hit just above freezing with a measured 33-degrees, adding a significant increase in energy required. That 219,450 BTU/hr = 64,314W. IOW, forgetaboutit doing it with electric. You could use one as an inline heater to boost the temperature when filling the tub from the tank, if you wanted.
    To cut down on the time for hot to arrive on the other side of the house, consider a hot water recirculation system. That will allow you to get the full capacity of the tank to feed your tub since you won't be throwing away a few gallons while you purge the lines of cold and warm up the pipes. If you can install a dedicated return line, all the better, but the retrofit systems that utilize the cold line also work. Mine is one of those. I find that if I flush the toilet before trying to use the hot, my cold line is purged of the warm water. Keep in mind that the systems turn off when the water gets warm, not full hot, so hot is nearby, but that also means your cold line isn't heated very much. Depending on the system you buy, that cut off point could be anywhere from say 85-105 degrees, and some of them are user adjustable. I find that when mine shuts off, hot is a few seconds away from my tub which is closer than the sensing location (under my sink). A recirculation system could be setup to be on demand, on a timer, or manually activated when needed. The one I'm currently using is made by Lang. The old one I had lasted nearly 20-years, and the company went out of business, so the part I needed (proprietary) was not available, otherwise, I'd still be using that one - the pump was fine.
Similar Threads: Extra heater
Shower & Bathtub Forum & Blog Extra turn to start water running Price Pfister 3-handled shower Aug 27, 2018
Shower & Bathtub Forum & Blog Problem fitting tub into alcove (too much extra room) Jan 15, 2017
Shower & Bathtub Forum & Blog Extracting stuck partial thermostatic cartridge sleeve due to mineral deposits Oct 5, 2016
Shower & Bathtub Forum & Blog Tub Spiggot broke off: PVC extraction? Aug 26, 2016
Shower & Bathtub Forum & Blog Stripped Screw & Broken Extractor - Shower Faucet Jul 17, 2016
