Hello Aristoc - thank you for the info that you provided, that was helpful. I flipped the dip switch 1 to ON and it seemed to help me get hot water faster to my upstairs sink/shower. I have a couple generic questions I'd like to ask:
1) Now that I finally turned on recirculation switch, do I need a bridge valve at furtherest sink upstairs? I've read several times about installing a bridge valve, but am unsure if it's needed.
1) I have seen in other forums/videos that when the home owners first installed the tankless water heater, everything was working fine, and he got continuous hot water. But then when his kids got older and started using more water, the kids would have to wait for hot water (their room was a little further away I believe). So does that mean that the standalone tankless water heater only works well when there are only a couple people using hot water? So if there are multiple people using water, then an external recirculation pump is needed? Or is it a distance thing?
Do you have a 210 or 240? The A model has that round pump inside. That is an internal pump. It doesnt look like you have a external pump connected because your Navien already has an internal pump that can be used to circulate water around externaly that it, from your fixtures which are all external . You have an internal pump but your are circulating water externaly. That red tube coming down on the left looks like it is an external recirculation line. Water is coming in from your fixtures in that tube. That two way lever valve should be set to external to let the water in. I wouldn't bother setting the temp higher than 120 degress. You should set up your Navien for external recirculation using the internal pump. That round pump will circulate water around and around all of your fixtures keeping warm water nearby when you need it. How often does it circulate around and around? Depends on your settings. You can set it so that it automatically recirculates when the temperature of the water begins to drop. The burner will fire up and rewarm the water. It will keep doing this automatically over and over again 24 hours a day. Or you can set it so that the Navien learns your habits and only recirculates based on the Navien learning your habits and sort of programming itself. Like if you wake up at the same time and shower every morning at the same time the Navien will pre-heat and circulate all that water ahead of time.
please double check the manual but for constant regular recirculation of heated water : you should have 1 OFF 2 ON 3 OFF If you want the Navien to learn your schedule than you can set 1 ON 2 ON 3 OFF.
