Nowell Dunwell
Well casing is cast iron (or is it steel?), about 4-5 feet below grade and stops. Previous owner (guy was here 40 something years and touched every, SINGLE, INCH of the property, inside and out, to my detriment) apparently used some type of 6" rubber coupler with stainless clamps and silicone sealant, which was a good 1/2" too big for the cast iron but fit the pvc... to connect a pvc extension above grade. Noticed water going yellow after a rain, and saw the extension wasn't level and was leaning slightly, and discovered the "diy" extension had pulled apart after digging 5' down.
I can either weld a new extension pipe on, or go with a dresser coupler. Pitless adapter hole is in the existing cast iron thankfully, so would prefer a pipe w/o holes.
Been looking online, and getting confused on what should be used or how it should be done. Actual OD of cast iron is either 5 1/2" or 5 5/8". Anyone have a link to dresser coupler to fit that and pipe for that coupler, or a pipe that can be welded over the existing cast iron? Need about 6' of pipe to be safe. Gonna need to hit it with a wheel flapper regardless, but dunno how even it'll clean up.
