Expansion Tank Requirement
DEK
13027 New York
I live in Baldwinsville, NY (13027) and my home is close to 40 years old. I have never had an expansion tank for my hot water tank. My hot water tanks have never failed prematurely - they last much longer than normal life expectancy. I don't know if I have a closed system or not. I contacted the town and they said my water meter does not have a check valve in it but they were not much help. The town has two wells and we are on one of them. Do you think I need to install an expansion tank?
Put a garden hose pressure gauge on a spigot , laundry tap, or the drain for the water heater.
Take a hot shower. Immediately stop using water (don't flush the toilet, for example). Look for a pressure rise. You can hurry, have a helper, or take a movie of the pressure gauge dial for viewing at leisure.
Sylvan
Still learning
New York
I only had one expansion tank that I had to install a tank for a 100-gallon tank.
A check valve on a watermain like this is ok for a water main
Fitter30
Peace valley missouri
If there is no check in meter or pressure regulator you don't need one. Any expansion foes back into the main. If the water company changes to a smart meter you will probably need one.
