Expansion Tank Precharge Low
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by WellNewb, Jan 8, 2020.
  1. WellNewb
    WellNewb New Member
    Jan 4, 2020
    NY
    Hey guys, injust received a new Amtrol expansion tank. The Precharge is supposed to be 38psi but when I tested it with 2 separate pressure guages, it measured 35.5psi.
    Is it possible that the charge is reading low because it's been in transit for a few days out in the cold weather and I should just trust that it's precharged to the correct amount?
    It's just weird that 2 separate pressure guages from different manufacturers would register 35.5psi.
    Thanks a lot!
  2. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    38 is unlikely to be the right amount either. City water, I presume. You want to set the air pressure to the same as the water pressure in your pipes when you have a faucet dribbling water. If that pressure varies during the day, I would try to set it to what it is max, if I knew that. Setting the air precharge to the same or 2 psi higher than the current water pressure will usually be near ideal.
    So why was the number lower than the published factory precharge? Maybe the Schrader valve slowly leaks. The valve cap should stop that if it is tightened normally. Maybe the unit was in stock for a long while, and air diffused out. Maybe you have two tire gauges that read a little low.
  4. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    Just the change in room temperature can make that much difference. Nothing to worry about. If you have a gauge that reads decimals you are probably more accurate than the factory. This is why I always stay to the low side of a pre-charge. Too little is OK, too much is not.
  5. WellNewb
    WellNewb New Member
    Jan 4, 2020
    NY
    I have a well with a 40/60 pressure switch so the tank should be set at 38psi from what i understand.
  6. valveman
    Mar 15, 2006
    Lubbock, Texas
    I would tell you 35 for the reasons above. You air pressure gauge will not read the same as the water pressure gauge.
  7. WellNewb
    WellNewb New Member
    Jan 4, 2020
    NY
    I'll just leave it alone then. Thanks for the input. It's an unfinished basement so the temps vary from 45 in winter to 70ish in summer. If its 35.5 now, I imagine it may be closer to 38 in the summer.
  8. valveman
    Mar 15, 2006
    Lubbock, Texas
    Yes that is how it works. Water temp makes a difference as well.
  9. Reach4
    Sep 25, 2013
    Since you called it an expansion tank, I had incorrectly presumed city water.
    If your precharge pressure is a bit high, it is not a big deal as long as you don't have a lever on your pressure switch. The symptom of too high is a momentary pressure dip when the pump turns on.
  10. valveman
    Mar 15, 2006
    Lubbock, Texas
    And tremendous water hammer when the tank bladder bottoms out.
Similar Threads: Expansion Tank
Pumps and Tanks Well Forum & Blog. Water is life. Expansion tank Pressure setting May 12, 2021
Pumps and Tanks Well Forum & Blog. Water is life. Need to drain old bladderless expansion tank for well Feb 21, 2021
Pumps and Tanks Well Forum & Blog. Water is life. Expansion tank life? Mar 5, 2020
Pumps and Tanks Well Forum & Blog. Water is life. Well pump or expansion tank? May 19, 2019
Pumps and Tanks Well Forum & Blog. Water is life. Expansion tank support Nov 6, 2018
