I'm sorry if this has been asked here in the past, but I did look and couldn't find it in a search. I've read you can heat PEX A to remove the sleeve and ultimately release a fitting for reuse. But even if you do this successfully, can that end of the PEX pipe be re-expanded or must it be cut back anyway?
I can see doing this to re-use the fitting (my understanding is only brass fittings should be reused this way), but I'm wondering if the end of the pipe itself can still be reused (re-expanded) to take on another fitting.
