beachloverjaxbch
- Messages
- 4
- Reaction score
- 0
- Points
- 1
Hi All,
There is an existing well on the property that has been working fine for many years, however, last year it stopped working and a new submersible pump was installed. The well company and our irrigation company told us that we had to have the pump on manual instead of auto because the well wasn't producing enough water and the pump would run constantly. ???? Well, last month, the well stopped working, even though we had the well on manual.
The well waters, the horse arena, the sinks in the horse barn, the horse washing stall, the pool, and the lawns. The other well which is fine, supplies the house.
I don't understand why we wouldn't be able to use the same well? Why do we need a new one? And if we expand in the future will this new well be sufficient. This has become very costly.
The new well estimate is as follows:
One new 4" PVC well, up to 200' using rotary method
Stainless stell wire wound well screen
All brass pitless adapter with riser to grade
5 HP FRANKLIN submersible pump with 2" drop pipe and #10-3-C cu conductor
Excavation area at existing well site and connect new well to existing offset line and existing cu conductor
$13,500.00
The irrigation company said they needed 55GPM 70PSI push system.
Does this sound legit? And what important questions should I be asking?
Thank you for your time!!!
Kathi
$13,500.00
Kathi
