RooferTryingAllTrades
I have installed a pressure tank into my home water system so that I don't have to refill the plastic water storage bricks every six months or pour my water out of this bricks when I need it. The issue I am having is that I have tried to explain to my wife that the water in the tank will rotate naturally. I can't convince her. Can someone help me have some confidence?
To simplify things, I just put a t after the water heater shut off, installed a gate valve and ran a line to the 120 gal tank. (30 days for 4 people. Have never needed 30 days worth of water or known anyone who has) As you all know these tanks don't function like a water heater, where there is a separate in and out. There is only 1 in/out. My thought about the water rotating is this. When water is used in the home, the pressure in the system drops, which means that the pressure in the tank will drop to equalize and water will flow out. Then when the water is turned off, the pressure from the city supply will bring the system back up to pressure and the tank will fill back up. Bam! Water rotated. (I'm not confident a significant amount of water will move. Will any water move?)
Is this sound thinking or do I need some valves or pumps or something else? Thanks in advance. Not in a hurry because I have six months before emergency supply needs to be rotated correctly.
