dosby
DIY plumber
As part of my walk-in basement renovation, I am redesigning a washer/dryer closet into a wetbar/laundry area. I am adding a kitchen/utility sink, overhead cabinets, etc.
I have bare concrete floor throughout my whole basement now.
In the laundry area, I am thinking of installing an emergency floor drain in case my new washing machine behaves. That is actually the only reason since the basement has remained dry all the time.
I am thinking of drilling a 2-1/2" hole through the concrete foundation wall right to my backyard, which slopes away nicely so that water would drain there fine. I understand I need to install at least 2" PVC pipe.
What I could not find online, is what kind of floor drain fixture to use and how to best install it.
Bust the concrete floor? How deep?
I understand that for emergency drain a p-trap is not needed, correct?
My washing machine would sit right above the floor drain on adjustable legs. I am not planning to install any flooring in the laundry area.
Is that a good plan?
Attaching a planning pic: grey squares are washer/dryer, the ext wall is on the left and the backyard starts sloping down ~6' from the wall. Interior concrete floor is level with the gravel outside, I think I could dig it up and lay a pipe there. Ext wall is ~8" thick with concrete up to 12" above the floor, not sure how deep in the ground it is.
