Ladiesman217
My ELM Aquastar 125vp ng tankless water heater is still working after 20 years of operation. Recently it became a bit noisy when water flow was fast.
I performed my very first heat exchanger flush this week. One hour of vinegar flush with pump, 2 hour wait with pump off, then one hour of final flush with pump. Then rinsed with clean water. The vinegar was still pretty clear after the flush.
After the flush I installed a new cold water input filter in the heater, and cleaned and lubricated the water valve. The water valve lubrication stopped the water heater noise.
The original thermostat has been bad for about 6 years (would not automatically regulate the gas - fixed position not variable). The old thermostat probe was perfectly clean when it was removed. No mineral deposits on it after 20 years.
I installed the new OE replacement thermostat that I recently picked up (two units, one spare), and calibrated per the service bulletin.
The unit now runs like new with regulated water temperature.
I also picked up some other hard to get water heater parts just in case I need them in the future!
I wonder how long this unit is going to last?
