pcarpe01
I plan on running 10/2 UVF cable from a sub-panel for a 20A dedicated circuit to power my shed. It is 10/2 due to the distance from the sub-panel to the shed. I am planning on a 20A fusible disconnect at the shed and since I am using direct burial, the trench will be 24" deep. The location where the cable would exit the house is insulated - covered with drywall and above grade (it is actually the garage). I have the following questions:
- Does the disconnect on the shed need to be inside or outside? is there a preference or requirement?
- How do I make the connection to the inside of the house - LB or similar? I am planning for a short run of PVC conduit to get the cable into the ground - 24".
Thank you in advance.
