I finally got the 24 volt wiring to contactor going but still not engaging even if i direct wire the 3 24v wires at unit to bypass stat...Contactor is fairly new..
Maybe the new part/coil relay helped.
Defrost relay tested an seemed to work fine.
4th capacitor at blower replaced also..
Compressor engages when contactor button pressed .
What should i look at next?
Thanks
Thanks
