I turned on the water heater at cottage for the first time yesterday. Nothing happenned.
I followed a online troubleshooting guide and I think I narrowed it down to a problem upper heater element. I did this with an ohm test but I am not up to speed with the different ranges on the meter. However the top element tested differently than the bottom... I do still have a question. Would there be voltage at the bottom element if the top one was bad? I read where the bottome element would not work if the top was bad but there was volatage at both.
The drain handle is plastic and rotates with the handle. I would like to plumb the drain through floor and use a ball valve to stop it. Does the plastic drain unscrew from the water heater? Can I swap it out? Do I need to use something made for high temps? I am trying to find an inexpensive solution to using a garden hose through the house.
