Bannerman
casing diameter is 8” only 27’ deep then no casing
Your well drillers report will normally specify the bore diameter below where the casing ends. While the overall bore will often be larger than the casing outside diameter (ie: 10" bore), it could also be smaller below the casing such as 6" or 4".
If we assume 8" ID all the way down to where the pump is located, then there is likely to be 112 gallons in storage within the approx 43' between the initial static water level, down to the pump inlet screen. Since you said the well recovery rate is. 2 GPM, your pump could likely pump at 10 GPM for up to ~13 minutes before the water level becomes pulled down close to the pump inlet screen.
If the pump rate was reduced to 5 GPM, your pump could then likely continue running continuously for 30-minutes or longer. If the pump rate was reduced to only 2 GPM, the water level should not drop much, even with the pump continuing to operate 24/7.
Since 2 GPM is equal to 2,880 gallons per day, the pump would only need to run for 16.67 hours to fill your cistern's 2000 gallon capacity initially. Since most household water consumption is less than 300 gallons/day, your well pump will likely only need to operate for less than 2.5 hrs/day to top-up the cistern each day, thereby ensuring only one pump will be needed to provide water for several days during a storm resulting in power loss.
Since the water enters your well above the pump location, suggest installing a flow inducer shroud around the pump. The shroud will ensure water will be drawn past the pump's electric motor, thereby ensuring the motor will be cooled whenever the pump is operating.
