Thor.266
Trying to determine potential cause for failure of the Reversing Valve for an electric Ameristar heating and cooling system—100% electric home. Outside heat pump compressor is 3 ton; which seems to fall inline with 1 ton per 500 sq ft., for a 1,500 sq ft 3-year old well insulated house in Washington—about 8 miles south of the Canadian border. HVAC company diagnosed with failed switch valve and needs new heat pump compressor for $10k—but parts under warranty—or an entirely new 2-ton system; including new air handler in the garage, for $20k. We were told system is oversized for the quality of the house build. Even if the heat pump is slightly oversized could that cause the failure of the switch valve? Or did the switch valve failure cause the heat pump to have issues?
