Mike in TN
I have a 40 gal. GE electric water heater that has started to blow off the pressure/temperature relief valve about once per day, depending on use. The system has a new (and apparently good) two gallon expansion tank in place on the supply, a new relief valve, new thermostats, and a pressure reducing valve on the supply line. The pressure on the supply line normally runs about 60 psi on a gauge and the pressure in the expansion tank was pre-loaded accordingly. Pressure on the system does go up to 140 psi as the water heats but the tank doesn't seem to be waterlogged. The system acts as if the expansion tank isn't even there. The temperature at the tap maxes out at the thermostats setting. Any ideas on what could be going on?
