mwhitis
My laundry supply lines are currently running from overhead and attached directly to my foundation wall. I'm remodeling the laundry room, and want to frame and insulate that area and put in a proper laundry box. I'll need to move the supply a couple of inches out to account for the insulation, etc. What's the best way to do this without needing to solder?
I know I'll probably have to cut into the overhead lines, and wasn't sure if replacing the laundry feed with something like pex or cpvc would be a good choice, or should I look into some sort of push on or compression fitting and re-use the copper (or get new copper)?
Thanks,
Mike
Thanks,
Mike
