Ph ranges from 6.9-7.6 ish, alk 80-150-ish.
That is
well within the normal range. More in the middle than at the extremes. I would go for
brass no problem. I don't think alkalinity is a relevant number for this purpose. I think corrosivity is. My alkalinity is 244, and my water does not attack copper. alkalinity would be useful to predict how much vinegar you would have to add to bring pH down for sanitizing. The calculation is beyond me, so I just add vinegar, and use pH test paper. Even if I could use the calculation, it would need knowledge of total volume of water involved and more.
Where does one find 1" Threaded EP fittings that can take Propex on the other end? I can't find them any where...if they're available, that solves a LOT of my problems! If I can get by with stainless steel just for the tank tee, and EP for everything else.......
I was mistaken. And this in stainless is expensive.
https://www.supplyhouse.com/Uponor-Wirsbo-Q8521010-1-ProPEX-Stainless-Steel-Male-Threaded-Adapter
How about using a couple of these?
https://www.supplyhouse.com/Mr-PEX-4021010-1-PEX-Crimp-PPSU-Male-Adapter But instead of connecting that end of the pipe with F1960 expansion stuff, either use a clamp ring or even a pair of worm gear hose clamps?
Haven't thought of CVPC, but would rather avoid it.
County (and insurance) will no longer allow PVC inside the house for potable water, regardless of if it works, common sense, etc....(i understand not after the hot water tank, but from the pressure tank to a filter? Come on...). Inspector sees white pipe.....red tag.......no
I think Illinois, maybe uniquely, allows PVC for cold water in a house, oddly enough, but I am not totally confident.
https://terrylove.com/forums/index....de-water-distribution-appears-ok-to-me.73428/ I have wondered if the PVC from wells is defacto allowed, at least to a point.
However CPVC is available not only in CTS, it is available as schedule 80 IPS. That is normally gray. Schedule 80 is much heavier. So while schedule 80 PVC might be overkill vs the common cts cpvc, it would add a lot of strength margin.
They use threaded 1 inch and 1-1/4 threaded schedule 80 PVC in wells to dangle pumps 200 ft and more a lot. They use poly to connect from the pitless to the house a lot. I wonder how much non-PEX poly the inspectors allow into the house.
