DWV Drawing for adding half bath--please comment
teddynono
DC
Hello,
Long time reader first time poster.
I am adding a half bath to one corner of my kitchen. I'd like to tie the toilet and sink into the existing 3" stack that serves the rest of the house.
How does my drawing look?
Thank you very much for your help.
Shacko
Master Plumber-Gas Fitter
Rosedale, Md
The only thing I would change is to wye off the toilet with a combine on a 45deg. angle and pick the sink up on a 2in. line and continue your vent, that will wet vent your toilet
teddynono
DC
Can you clarify what you mean by "wye off the toilet with a combine?" I'm not sure what fitting this is. Thanks very much for your help!
He means a "combo", which is NOT the fitting for either the toilet or the sink. Do NOT use "Y"s either. You use plain sanitary tees to connect both the toilet and the sink.
teddynono
DC
I have re-drawn to include the specific fittings that will be used. Am I using the right fittings?
Key:
Red = new
Black = existing
Dashed line = vent
Solid line = waste line
Thank you.
Dlarrivee
Canada
"new 2" vent wye"
I don't under stand why or how you could use that there unless you used a 45 elbow as well, but why use a wye in the first place...?
I'm pretty sure HJ wasn't talking about using a sanitary tee where the w/c line ties in below the sink... I don't know how much room you have in your crawl space, but I would rather have the line bend 90 degrees before I dumped the w/c into it rather than bend 90 degrees immediately after.
He has it EXACTLY as I meant it, (although there are many possible variations depending on space limitations, head room, etc.), other than the "vent Y" should be a sanitary tee, and he does not have it inverted as it should be for venting purposes. I would also put the vertical riser behind the lavatory to eliminate the horizontal arm.
teddynono
DC
Excellent. Thank you both for your input and comments. Very helpful.
One last question. Depending on the amount of room in the crawl space, I am also considering an alternate approach. Would this drawing work also?
Note in the drawing the sanitary combo would be oriented with the 2" portion facing upwards.
Thank you.
teddynono
DC
One more question. I should probably install a clean out since my house is so old that it does not have one. Where would be a good spot to install a clean up in the two drawings?
Thank you.
