JoeNotThePlumber
Hello,
I am not a plumber but a fairly experienced DIYer. I am currently remodeling a second story bathroom in my 100 year old foursquare in Michigan. I have completely gutted the thing and am beginning to put it back together. I need a bit of advice and input on the waste lines and vents. I will try to keep this organized as clearly as I can.
How it is now:
The cast iron stack is directly behind the toilet. Toilet sat on a closet bend with a side inlet on either side. The lav drains into one side and the tub into the other. Neither the tub nor lav have a vent. It is just 1.5” galvanized pipe from the trap to the inlet under the toilet. The tub used a canister trap, the lav a modern P-trap.
In the basement a previous owner removed the cast iron stack from the basement floor up to the basement ceiling. There is now PVC to the floor and a 3” branch that serves 1st floor powder room. The iron stack runs up the first floor wall with no connections on the first floor at all.
What I am setting out to accomplish:
Bring this up to modern standards to avoid waste water coming through the ceiling(again).
Add hook-ups for laundry machines in the very large hallway closet.
My plan:
I will remove the cast iron stack in the wall I have exposed (second floor and attic).
I will run 4” PVC from the basement all the way to the roof.
I will plug the top and bottom of the old stack and just leave it in the wall. There is plenty of room in the wall cavity and moving the toilet over 6” does not bother me. I do not want to tear up the first floor walls to remove it.
The toilet will drain directly into the new stack.
The only other connections to this stack are an existing vent, a vent in the attic I will add and a 2” PVC pipe that I will describe below.
This pipe will start 4 feet off the floor were it will connect to the new stack. It will run behind the lav and down into the floor. It will travel across the floor turn 90 degrees and down to the basement where it will connect back to the stack.
This pipe will drain the lav, laundry drain, and tub and vent the lav and tub. I will run a vent for the laundry trap up into the attic and connect it to the new PVC vent stack.
There is a drywall soffit/column on the first floor below the bathroom that I can run the 2” pipe in.
Questions:
1. Any issue abandoning the cast iron in the wall? (at least until there is another reason to tear into the first floor walls)
2. Does my design make sense? I thought of coming across the floor in front of the toilet and draining everything down the main stack rather than down the soffit to the basement. I thought avoiding the big notches in the joists was a good thing since the laundry and tub will need 2” pipe. By the time I account for .25"/foot of drop the notches will be way to deep.
3. I was going to add cleanouts under the lav and below laundry trap. Any place else? Most of this will be completely covered by wall tile and floor so my options for clean outs are limited.
Thanks in advance!
How it is now:
My plan:
Questions:
Thanks in advance!
