Thanks everyone for the suggestions and comments -
Mr Tee -
Thanks for the tip on the combination. That was original to the '69 build - maybe it was code then - or maybe that was their last ABS fitting in the bag.
Terry -
Wet venting is an interesting topic. One that seems to come up often on these forums. Thanks for sharing the diagram. Certainly don't want to siphon my traps and fill my house with sewer gas - at least not today.
Tuttles Revenge -
It is concrete slab with cast-iron underneath. I think you are right though - this is likely due to a confluence of multiple issues. Grease/fat from the kitchen, lint from the laundry, and no easily accessible cleanout for this branch under the slab. It's also possible there are some other slope or snag issues in the under slab drainpipe as well. I like the idea of having a new dedicated 2" connector - but that drainpipe is offset from the vent by about 3-4", which is behind this wall with the vents - and it would be an even larger endeavor to break into that area in the other room.
Wayne -
Checked up on that lav drain/vent - and it was indeed 1.5", but coming out of the slab it was reduced from a 2" connector, and under the slab the wye connectors are all 3" cast. So went a bit further with this idea and pulled that 1.5" ABS out of the larger hub, and replaced with 2" PVC. Then rerouted the kitchen drain from the end of the branch to the new 2" drain under the new lav sanitary tee.
Sylvan -
Turns out that shower drain is 2" ... need to recheck my eyes.
We did get into the slab to move the flange, and the shower drain - and a little more exploration. From what we can see, the pipes look ok, though the 3" cast iron drain connector that was cut out from the kitchen line had a significant amount of soft waste in it (50-60% filled). While we were here we also put in a cleanout at the end of the branch drain where the kitchen drain had previously been routed for good measure (and maintenance).
Pictures - because plumbing is awesome:
Under slab - just soft dirt down here.
New 2" lav drain (left) and 2" kitchen drain (right).
New clean-out extension.
