So what is the minimum power consumption for housekeeping and running the indoor blower motor? Dana, do you know that number?
What is the right size/capacity? Since VS heat pumps run more efficiently under partial load than at full speed, it seems like a complex decision whether to size them exactly or oversize them some. In some cases, it may boil down to how you are using them, setback or no setback.
Robert, do you have remote control over your systems so you can turn it off if you want to? Do you run it on auto changeover mode to keep humidity low in warmer times when you are not there?
I like the mini split operation. I'll tell you one reason, however, that I might not fill a multi-room house with mini splits again. There is a great increase in mechanical complexity. I've replaced one blower motor for about $150. Beyond the cost, it was hard for me to purchase since most HVAC supply places don't seem to want to sell to homeowners. I hope that I don't need to replace more of them.
Last summer, I pulled out the blower cages on my Mistu MSZ indoor units and spent 4-5 hours each cleaning of 6 of them. The blower cages and the inside of the case that they can "throw stuff at" were disgusting after 5 years; black gunk was everywhere. (See the comments on the video that I post below.) I did the blower cages in the driveway with neutral detergent followed by a brief hit with bleach. While I was out there I also cleaned the outer case, both sets of louvers/vanes. the drip tray (nozzle assembly), and front panel. A soft gong brush, tooth brush, a common hose-end sprayer and cotton swabs were useful. Note that vertical louvers have been a PITA for me to release and hinge out of the way. I bought a bib kit to clean the indoor coils and remaining parts on the wall and it was well worth it. I sprayed what little visible stuff was caught in the coils with foaming cleaner and then thoroughly sprayed with a tank sprayer with Nu-Calgon Evap Pow'r-C and rinsed.
Note that Mitsubishi finally posted some disassembly vids on YouTube. They were helpful. The service manual not so much for neither the cage removal, nor blower motor replacement. Honestly, the manual was a PITA for the latter. Jeff is my new best friend:
I just had a look and there are a lot more vids available now. I can't comment on the quality.
