Dual Trip Breaker Replacement
Snets
California
I have two Type BR dual-trip breakers (15A) in my panel for what I think are called branch circuits (four circuits - that is two 14-3 wires with red and black hots, one common each...they share a common so when one trips, they both need to trip (red and black) I think I have that right.
The two breakers take up 4 positions in the panel. Can I make a little more room by using a Eaton BQ215215 for the four circuits? That would only take up two spaces......
Yes, although I am less than enthusiastic about the metal "bridge" that ties the two outside handles together. And you have to be certain to tie the "correct" circuits into the four poles.
Stuff
Pennsylvania
That is a tandem/quad breaker. Some panels do not take them and others only in certain positions. Take a look on the label on the inside of the cover. It should list BQ breakers along with BR.
Snets
California
There is no label on the panel, no info whatsoever. I have similar BQ breakers installed for the dryer (220V) and for a spa (220V)
Snets
California
I decided to install a sub panel and leave the main panel alone. I already had a 50A 220V breaker and 6 Gauge 4 wire NM running to the location where I stubbed the new 110V circuits (Was previously for a hot tub that has been removed). My sub panel now has two 15A GFI breakers for the two circuits I needed for the outdoor kitchen.
I feel better about this install than trying to squeeze more circuits into my 100A main panel which is full.....Almost....I have one 20A leg of a quad 20/50 breaker unused.
Speedy Petey
Licensed Electrical Contractor
NY State, USA
From the sound of it you would have been fine installing that quad, but you are obviously past that.
