Dual pressure tank distance
Kennyandnorma
Houston
I’m in the Houston Texas area. I’m new to country living.. My well is approximately 50 yards from the house, has a pressure tank at the well site with the ground level pump. I also have a pressure tank in the garage of the house. The well pump is set to 30/50 and has been fine. Yesterday out of no where the pressure on the garage tank read between 28psi and 34 psi where it has been a constant 40-45psi. Do these tanks have to be synchronized? Is it a pressure switch issue? Help !
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
Pressure will be the same in all parts of the system. Probably just a bad gauge. Having more than one pressure tank is not needed, and more than one in different locations can cause issues. "New to country living." Should look into adding a Cycle Stop Valve. Then not only will your residential water system deliver stronger than city water "constant pressure" to the showers, but you only need one small pressure tank like 4.5 gallon size.
