So first of all, so much info has been gathered here by so many different people I had to make an account.
We are building an addition and with it a master bath that's 7x13. My plan is to put in a curbless shower that's about 73x44 without any partition to the rest of the bathroom. This bathroom will have two shower heads and valves and share one exterior wall. This will be supplied by 3/4 pex main line and branched to 1/2 pex up to the valves. This will be covered with cement board (next gen 4x8 on 16" PC studs) which will be waterproofed with regard. I plan on using a sand cement mix fitt the bed. I hope that covers what might be needed to give a possible answer/suggestion.
On to the question. I ordered a 60" inch linear drain due to not finding a 72" under 500$. Is there an issue using a drain that size for the measurements given. The other thing I think would be nice may be using dual 36" linear drains. Two 36" linear drains still puts me way under the 600$ plus for a 72" drain. What's the best plan to go with?
Thanks in advance all.
