Thatdarncat
Hi Folks,
I have a 400' well with the static water pressure at 50" below the surface.
I want to use a 1-1/2 hp 120v pump, the reason for 120 volt is so that I can power it with a generator when the grid goes down during winter ice storms.
The well is about 75 feet from the service panel and I want to drop the pump to a depth of 380 feet.
What gauge wire do I need for the run? ( the pump comes with 130 ft of wiring) Or would I need larger gague the full run to the pump?
Lastly, could I used 3/4 ads flex pipe or should I stick to 1 inch ads pipe...the reason I would like to use 3/4 is I can get a continuous run of 3/4 pipe 400 ft long , while I can only get 300ft of 1 inch ads flex pipe whiltch would require a coupling point.
This is only for use in my small home of a family of three.
Thanks for any help you can toss my way!
