Rman
Master mechanic
I plumbed my whole house three years ago while under construction. Now in the basement where I can see the fittings three have started to drip slowly!! I’ve removed the stainless steel pinch clamps cut back a few inches and still started to drip
I then removed the fitting with a new one and no leak. How do I stop this from progressing to all the fittings throughout the house?
Is this a few crappy fittings or is this a disaster in the making? All parts were ordered from a supply house. My well pressure is thru a CSV at 55 psi running and 70 psi off. PEX should easily handle 100 psi. Btw the oxygen free PEX on the heating system No leaks but same fittings!! Help
