Drake II "Footprint" / Installation
Discussion in 'Toilet Forum discussions' started by LeoD, Nov 7, 2019.
  1. LeoD
    LeoD New Member
    Nov 7, 2019
    LA, CA
    Hello. Great forum. Thank you Terry, and everyone who posts!
    I want to replace a Kohler Wellworth 1.6gpf round with a Drake II 1.0gpf elongated. I was about to order the Drake II when I realized from the pictures and diagram on Toto's site that its base extends farther back than the Kohler.
    When the previous owner installed the Kohler, he moved the supply valve to the floor, and I don't think it will clear the base of the Drake II.
    Toto's diagram shows the base as 9 7/8" at the widest point. My current supply valve is about 8 7/8" back from the center of the outlet. Does anybody know the width of the Drake II at this point?
    It looks like my only option if I want to install the Drake II may be to move the supply valve. If I do, I'm hoping the toilet base will cover the patched hole.
    Additional questions:
    1. Is there some device or trick I'm not aware of that would save me from moving the supply? (I'll need to work in a very narrow crawl space, if I need to move it.)
    2. Is there another toilet, comparable to the Drake II that might fit without moving the supply?
    3. If I do need to move the supply, is there any way to install the pipe in a tiled wall without removing tiles, or am I better off just relocating it to another spot on the floor?
    Thanks again!!
  2. Terry
    Aug 17, 2004
  4. LeoD
    LeoD New Member
    Nov 7, 2019
    LA, CA
    Thank you for the quick reply, Terry!
    That looks like it might fit if I trim the supply valve flange a little. It's also on the qualifying list for rebates in my area (something I failed to mention before.)
    How does it compare to the Drake II, which gets so much love on this forum? Is there some compelling feature that would make the Drake II so much better that it would be worth crawling under the house and sweating copper to move the supply, or would I be just as happy with this one?
    Also I see that there's a new 1.0 / .08gpf Drake (CST746CUMFG) that is also on the qualifying list. Any idea whether this ultra-low flush model will perform well?
  5. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
  6. LeoD
    LeoD New Member
    Nov 7, 2019
    LA, CA
    Thanks for your reply, Reach4. I didn't realize until you mentioned it that Dynamax is different than Tornado!
    It appears the difference is that Dynamax flushes entirely from the rim - no siphon jet. Is it inferior? I only see a couple of reviews online for it so far.
    Does anyone here have first hand experience with it?
  7. Reach4
    Sep 25, 2013
    I had missed the implication that there seems to be no siphon jet. Never seen it.
  8. LeoD
    LeoD New Member
    Nov 7, 2019
    LA, CA
    Yes, I saw the video with the water swirling around from the rim thought they'd gone with the same flush system as the Drake II. After you mentioned it's a different system, I looked up the TOTO Dynamax page and found this:
    "With conventional siphon jet flushing systems, the water volume is split between the rim and jet hole, with each responsible for bowl cleaning or waste evacuation. DYNAMAX TORNADO FLUSH® however sends 100% of the water through the rim so all of it is used to clean the bowl and to evacuate waste."
  9. Reach4
    Sep 25, 2013
    Dynamax would make for better plunging... not that plunging is common with a good toilet.
    When plunging most toilets, a lot of the water flow, and maybe some solid material, is directed into the siphon jet. With no siphon jet, all flow would go out the exit.
  10. LeoD
    LeoD New Member
    Nov 7, 2019
    LA, CA
    Hadn't even considered that, but it makes sense. I also read somewhere that this new Drake has a shorter, lower trap - which might also make for easier plunging.
    I'm curious how well it flushes (and performs in general.) I've only found 5 reviews online so far, 3 good and 2 bad. I'd trust the experience of someone here more, if anyone has this model. (Or Terry, have you installed enough of them to have an opinion?)
Similar Threads: Drake Footprint
Toilet Forum discussions Drake or Vespin-Which model has the largest footprint-want to cover up old footprint Dec 7, 2011
Toilet Forum discussions Footprints dimensions for Drake and Ultramax Feb 29, 2008
Toilet Forum discussions Blue-Green Scratches/Stains at Bottom of Toto Drake Thursday at 7:05 PM
Toilet Forum discussions Difference between CST746CEMG and a Drake II? Monday at 10:15 AM
Toilet Forum discussions Drake II or Kohler Cimarron Oct 15, 2019
