dbump
I'm simplifying the plumbing at a mountain cabin while gutting a bathroom, and I'd like to streamline the winterizing process. One of the things I'm considering is draining the water heater back into the well. Is this crazy, or even possible? I'm not sure if the well will allow water to drain back into it, or if check valves in the well would prevent that. I'm only interested in not wasting 50 gallons of water each time I winterize--currently, our winter usage pattern is to use the cabin one or two weekends a month between November and April, and we winterize when we leave to save on heating costs. While the water is "free", I'd be much happier returning it to the deep water table than the shallow one.
Speaking of check valves, the current system has a check valve between the pressure tank and the rest of the indoor plumbing. It would make more sense to me if the check valve were instead between the pump and the pressure tank, so that once the pump has pressurized the tank, and shut off, the pressure tank isn't trying to force water back into the well. Obviously, this isn't actually happening (which is what makes me think I won't be able to drain back into the well), since the system works. What am I missing?
