rmcderm313
Hi All,
I am planning on extending a baseboard forced hot water radiator in a foyer. I’m waiting for Spring in case I run into any issues, I don’t want to be without heat. I have some questions about that extension as well but I’ll save those for a later thread.
First things first, I’m hoping to get some guidance on draining my system for the repair, and then refilling it when ready. Here is a summary of my system.
Burnham Series 2 Gas Boiler
Burnham Indirect Fired Hot water heater model PAL-41 (41 Gallons)
I think I have a good handle on how it’s set up, but if I am off on anything here please correct me. Refer to the picture with the numbers on it for this description. The red vs. black number have no significance, I just used red where it would be hard to see black.
#1 is the incoming domestic water line shut-off for the boiler
#2 is the domestic (cold) water feed for the indirect water heater
#3 is a branch off the domestic water that feeds the boiler. It has a shutoff valve, and…
#4 a Watts low water pressure reducing valve, and a Watts ½” 9D-M3 dual check valve backflow preventer (as an aside, I’ve read mixed opinions on whether this shut off should be in the “on” position, but in my case it is)
#5 2 Taco circulator pumps (return side) connected to each of the 2 zones (upstairs and downstairs), each with a shutoff valve.
#6 Refers to this general area which is a loop to connect the heating coil in the indirect water heater to the boiler.
#7 Another circulator pump (supply side this time) that pulls heated water from the boiler on demand, through the loop mentioned in #6, to heat the tank water.
#8 The supply side output from the boiler. In addition to this being connected to the pump mentioned in #7 above, it feeds the baseboard radiators in the two zones. Before feeding the zones this is connected to a Taco Air Scoop with an expansion tank (see pictures).
#9 A bank of 4 hose bibs, one each for the 4 return pipes from the radiators.
I have the installation instructions from Burnham that speak to filling the system, but they don’t jive with how the system is installed in my case. First of all it doesn’t include the indirect water heater (not surprising) and the related complications that introduces. Also the circulator pumps that feed the system in the instructions are on the supply side as opposed to on the return side like they are in my installation. I believe that results in shut off valves and hose bibs being in different locations. All of that makes the instructions pretty useless.
Based on generic instructions I’ve found on draining a system, my thinking is to:
Shut off the boiler (electric switch on boiler)
Let the system cool (2 hours)
Shut off the incoming water valve at #3
Start with the hose bibs at #9, connecting a garden hose one at a time, open and drain each one (I’ll need to use a 5 gallon bucket because I don’t have a floor drain)
Open the bleeder valve on the furthest radiator to help the system flush
Here’s where I’m stuck. Should I just open every hose bib (connected to a hose of course) that I can until they stop draining? As you can see there is one right at the return side of the furnace, as well as one on the return side of the indirect heater loop. I’m just not clear on what will effectively empty the system enough to make my extension (which is on the first floor).
Then, what is the correct method for refilling once I’m done? The Burnham instructions say to use a garden hose connected to a hose bib on the supply side, which in my case doesn’t exist. Based on other reading I’ve done, I should be able to simply turn on the domestic water valve #3 and the system should fill until the low water pressure reducing valve stops it at 12 PSI (or where it’s been set).
So overall, my system has enough differences from anything I’ve been able to find online that I’m just not sure how to go about this. Any and all assistance is appreciated.
Thanks,
Rob
PS - As you’ll see in the photos if you go to the album, the PSI on the boiler is North of 12. Looks to be more like 15 PSI. Is that an issue?
Thanks,
Rob
