I need to move/remove 2 drain vent pipes because These two drain vents run right through the space. The one on the left goes through the roof up top. The one on the right comes from below and links up on the wall with a bathroom sink on the other side of brick and then goes up to the roof as you can see in the pictures.
I need to get both moved so that I can make the space usable.
What do you all recommend?
