Drain stub location
JazzJohn
Wisconsin
We have a building that we think has a buried drain stub that was meant for a future shower. It has been concreted and epoxy-floored over. In the same area are a stack, toilet and sink drain. All pvc.
What's the best way to find the end of the pipe (if it exists) without breaking up the floor first? We have a rough idea where it should be because there are overhead supply lines for the faucet. Can a camera snake be routed from the stack to take a turn into an arbitrary connected pipe?
Chucky_ott
Active Member
Ontario
That's my thinking. Or at least the large void from the pipe would affect the concrete temperature. Not sure I'd buy a thermal camera just to find out if it works.
Alternatively, a snake and metal detector. Not sure I'd buy a metal detector to see if that works.
Not sure what the pros use for their locates.
At least the thermal camera has other uses around the house.
Thinking about that thermal idea. One thought might be that under a heated floor in winter, the area with no plastic pipe would run cooler. That air might be an insulator enough to make a difference.
Another thought I had is to block the path (with a Cherne test ball) below where the other drainage joins the toilet drainage. Circulate hot water between the closet flange and the lavatory drain. The shower would be a dead end, so the bulk of the pipe would not heat up, but maybe turbulence would heat the first few inches of the path from the shower. Likely that is a 45, so project a line...
See if any of your friends have a FLIR camera attachment for the mobile.
Just speculating. I have no relevant experience.
