HereInOhio
I'm trying to figure out the typical height to install my horizontal drain pipes. One wall has a 2" washing machine standpipe drain going through it as well as a separate 1 1/2" utility sink drain that needs to go above it. I'm in Ohio so under IPC. Do you know if it specifies a min/max height?
The other wall is just a double lav that will lead into a drain in the floor. Here again I'm wondering what height to run the pipe horizontal at? This wall will also need a vent pipe running horizontally through it, which will include a shower head in the middle. I know the vent has to go above the flood level and would assume all the way at the top by the ceiling is a dangerous zone since someone could install crown later on. With the shower head having to extend high on the wall it would be nice to have it above so the supply pipe to the shower head doesn't need to wrap around the vent but it would be pretty close to the ceiling. Any recommendations or advice would be appreciated.
