chrisharper80
Hey all, my name is Chris and I'm new to the forum. Working on a bathroom DIY job. The tub surround was done incorrectly (normal drywall, no waterproofing under the tile and the backing didn't overlap the tub flange...as well as a non-waterproofed window with water leaking through the sill). I have demo'd everything and discovered that the bathtub drain was plumbed in strangely. There are 2 drain pipes coming up from the subfloor. One is the normal bathtub drain. The other one makes a bend into the wall cavity and goes up and turns left towards the sinks. Not 100% sure exactly where that one goes (maybe the sinks share the drain pipe?).
The problem is that this other drain pipe comes up exactly where the corner of the tub should sit. Looking at the old tub I removed, it looks like they just removed the 45-degree bracing piece from the side of the tub so this pipe sat in the hollow area of the tub. I'd really like to avoid doing that because it will make the tub flex a lot more than it should and likely lead to cracks the caulking around the tub flange.
Looking at how this is set up, I think I could switch these at the wye, run the P-trap directly across to the drain and drill a hole in the framing with an elbow to run straight up into the pipe. The single pipe connecting into the wye is directly under the wall cavity so an elbow up through the framing would run right into the wall.
Is there any problem with swapping the way these 2 lines come out of the wye? Any other ideas? I have attached several pics. Thanks in advance...plumbing isn't my strong suit.
